How much water in header/expansion tank
Very quick question, as a general rule how much water should be in the header/expansion tank whilst cold and whilst hot? (Measured on a level surface of course)
There are a pair of lines molded in to the plastic. The level should be between those lines. At least that's how they do it on this side of the Atlantic.
Unfortunately there is only a "Cold fill max" line on these moulded into the plastic, so its quite difficult to judge what is the 'right' level as opposed to it being at max whilst cold!
Originally Posted by andyb2000
(Post 71860)
- I just fill to 'about [ish]' the cold fill line - I've never had a moments trouble with it - and mine 'still' needs a new stat - still haven't got around to doing it |
Cheers m8.
Unfortunately its down to the ongoing saga with mine as just spoken to the garage and after over a month in getting all sorts done, its off on its way back in now :-( |
(Post 71864)
Cheers m8.
Unfortunately its down to the ongoing saga with mine as just spoken to the garage and after over a month in getting all sorts done, its off on its way back in now :-( - owt I can do to help .. .. just ask ! |
(Post 71860)
Thanks fellas.
Ack, bad news QinteQ, it's dead. Cracked block (discovered now the sump was removed), so its either scrap or try and get a replacement engine for it, but looking at cost and worth don't think it's gonna be worthwhile. Might end up stripping it down and selling parts though. Gutted as I loved my GV :-( Ta for the advice and support tho fella. |
Andy lad there seem to be soddin hundreds [ebay scrappies] if not thousands of Voyagers around the Bradford area if you decide to look for a block, relatively sod all up here. Do a trawl of scrappies around here - see what you come up with. There'll be others like you somewhere local scrapping theirs with a good powerplant and an uneconomic gearbox.
Best 'o luck M8, and sorry for you - exactly because we all love our GV's |
Yeah, I know. Considered doing the engine swap thing, but since I'm not mech minded i'd always have that in my mind.
So unfortunately I'm on my way, its been scrapped and I've moved onto Citroen I'm afraid so leaving the Chrysler behind now. Thanks for all the help in the past folks, QinteQ also for all your help m8 appreciate it. |
