-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   How to replace MF Switch? (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/how-replace-mf-switch-4129/)
VFRbeliever Nov 8, 2007 11:47 AM
Hello all,
How easy is it to remove and replace the multi-function switch on an '04 Town & Country? Mine won't cancel when it is in the down (left-turn) position. I have to push it back up manually every time I make a left turn, and it's kind of a pain. The part is $50 at the dealer, and I'd like to just replace it myself. I haven't sprung for a service manual, so I don't have any instructions or diagrams. Are there any special tools required? Any tips would be appreciated.
Thanks,
Chris
moe Nov 8, 2007 08:23 PM
RE: How to replace MF Switch?
REMOVAL
[ol][*]Disconnect and isolate battery negative cable.[*]Remove upper and lower steering column shrouds. Refer to Steering, Column, Shroud, Removal.[*]Disconnect wire connector from back of multi-function switch.[*]Remove screws holding multi-function switch to steering column adapter collar.[*]Remove the multi-function switch...................... let me know moe i'll get you some pictures[/ol]
moe Nov 8, 2007 08:26 PM
https://w05.dealerconnect.chrysler.c...S/808b14cc.gif
moe Nov 8, 2007 08:28 PM
1 - CLOCKSPRING WIRING
2 - STEERING WHEEL
3 - UPPER SHROUD
4 - FIXED SHROUD
5 - SCREW
6 - STEERING COLUMN MOUNTING PLATE
7 - NUT
8 - DASH PANEL STEERING COLUMN MOUNTING BRACKET
9 - STUDS 4
10 - STEERING COLUMN LOCKING PIN
11 - NUT/WASHER ASSEMBLY
12 - STEERING COLUMN ASSEMBLY
13 - LOWER SHROUD
14 - SCREWS
15 - STEERING WHEEL RETAINING NUT
16 - STEERING WHEEL DAMPER
17 - CLOCKSPRING
18 - SCREW
19 - MULTI-FUNCTION SWITCH MOUNTING/HOUSING
20 - PINCH BOLT
21 - STEERING COLUMN COUPLER
22 - PINCH BOLT RETAINING PIN
23 - DASH PANEL
24 - SILENCER SHELL
25 - INTERMEDIATE SHAFT SHIELD AND SEAL
26 - INTERMEDIATE SHAFT
27 - ROLL PIN
28 - STEERING GEAR
29 - FRONT SUSPENSION CRADLE
sorry about taking up so much space!!!hope this helped moe
