Howling from passenger rear
Old Apr 3, 2018 | 04:21 PM
Bones1980's Avatar
Default Howling from passenger rear
So a couple weeks ago my wife was complaining about a howling noise coming from the passenger rear. She said it sounds like a motorcycle is beside her. I pulled the wheel off and gave it a once over. The rotors needed replacing. So put on new brakes and rotors. Also spun the hub to check the bearing. Bearing spun a little hard and was making a clicking noise. So I replaced the hub assembly. They noise is still present. I've also tire rotating tires. Anyone have any ideas. Diff maybe?? The howling does get a little louder while going around corners
Old Apr 3, 2018 | 04:29 PM
REBEL59's Avatar
Might get more help if you gave a little more info of what you are working on. Year,trim(awd?), mileage. You have about hit all there is except possible parking brake issues inside the rear rotor.
Old Apr 3, 2018 | 04:42 PM
Bones1980's Avatar
Default 2010 town and country
Sorry it's a 2010 town and country. 4.0 and front wheel drive
Old Apr 3, 2018 | 04:45 PM
REBEL59's Avatar
Well that changes a lot of possibilities, so what end of all this work you did is on(the FRONT?) you post the noise sounded from the REAR.
Old Apr 3, 2018 | 04:47 PM
Bones1980's Avatar
I have heard parking brakes make a clicking or crunching noise. Never heard one howl. So I never even considered or checked it. I'll check that out tomorrow and see what happens. Thanks
Old Apr 3, 2018 | 04:50 PM
Bones1980's Avatar
It's coming from the rear passenger side. I sat in the back the other day. It was louder that side. I also check the rear driver side. I didn't notice anything
Old Apr 3, 2018 | 04:52 PM
Bones1980's Avatar
So all the work was done on rear passenger side. Rotors and brakes on all 4
Old Apr 29, 2019 | 09:32 AM
bhadcock's Avatar
Default Rear Evaporator Howling sound?
I have a 2010 Chrysler T&C with the 3.8L. We had no cooling two weeks ago and my mechanic found the rear evaporator coil on the passenger side leaking refrigerant pretty bad, so $650 it was replaced. I now have cooling but when driving locally from 5-45 mph I will occasionally get a howler monkey sound on the right rear of the van, at highway speeds it does not do it. The sound literally sounds like a howler monkey, no joke. It lasts for maybe 3 seconds and goes away, it is not consistent and does it whether the A/C is on, ***** are on heat or cooling, it may make no sound for awhile, then all of a sudden you hear it and its gone. At first it sounded like a motorcycle (crotch rocket) going by but we noticed no motorcycle near by. I have talked to my mechanic and this is a first for him. I am wondering if it may be one of the actuators in the passenger rear? It never caused this sound until the rear evaporator was replaced, could it possibly be a part in the rear evaporator unit itself? Any help would be appreciated.
Old Apr 29, 2019 | 11:39 AM
REBEL59's Avatar
Before tearing things back apart...Have them put a/c gauges back on and recheck high and low side pressures and for full fill of refrigerant,making sure that rear a/c is full on. It's a pretty long distance for the a/c compressor to pump from the motor to the rear and back.
Dennis M Hazard
Aug 24, 2017 02:54 PM
jdewey95
Jun 11, 2015 08:12 AM
scotto58
Oct 28, 2014 04:51 PM
dakzak2004
Dec 4, 2013 06:52 AM
tachrcn
Oct 11, 2009 07:30 PM
