-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   Hvac controls & switch illumination (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/hvac-controls-switch-illumination-12422/)
moparrh Sep 15, 2010 11:56 AM
The heating & air conditioning control panel bulbs can be replaced with radio shack #272-2254. The bulb for the mirror switch can be replaced with #272-1092. You will have to carefully remove the sleeve on the bulb & re-use the twist in socket. Heated seat switches & some other switches will also take #272-2254. If your not handy with a soldering iron, take it to an electronics repair shop. I doubt they would charge a great deal. Hope this helps.
moparrh Sep 15, 2010 12:08 PM
[quote=moparrh;40800]The heating & air conditioning control panel bulbs can be replaced with radio shack #272-2254. The bulb for the mirror switch can be replaced with #272-1092. You will have to carefully remove the sleeve on the bulb & re-use the twist in socket. Heated seat switches & some other switches will also take #272-2254. If your not handy with a soldering iron, take it to an electronics repair shop. I doubt they would charge a great deal. This was done on my 2001. Hope this helps.
xjr41 Sep 28, 2010 04:37 PM
Hi,
I also need to replace the bulbs in the switch panel. Can you advise the spec of the bulbs as we don't have a radio shack in the UK and I would need to know current etc to be able to source replacement bulbs.
Thanks,
Steve.
moparrh Sep 30, 2010 08:12 PM
Hvac & switch bulbs
THE BULB FOR THE SWITCHES IS 60mA. BULB TYPE T-1. BRIGHTNESS .15MSCP. LAMP TYPE 7219. BULB FOR HVAC CONTROLS IS 50mA. BRIGHTNESS .12MSCP. BULB TYPE T-1
rodger Oct 1, 2010 07:12 AM
Hi
I got bulbs and LED from Maplins in UK
https://www.chryslerforum.com/forum/...ad.php?t=10916
big walt Mar 17, 2011 04:03 PM
Which switches are you referring to and which bulbs for the HVAC controls are you talking about. i believe there are two different types of bulbs in the HVAC control. I ask this because most of mine are out too.
moparrh Mar 18, 2011 11:08 AM
Bulbs are for the hvac controls, not the amber l.e.d's. Switches are the mirror, headlamp, heated seat swithes etc.
rodger Mar 18, 2011 05:05 PM
Hi
My response is for the centre console "Icon" bulbs ie.not the rotary yellow "volume" leds.
I also replaced the hazard light with an led.
It's not that hard a job.
barwaryzaid Mar 25, 2011 04:47 PM
Originally Posted by rodger (Post 41430)
Dear i just would like to know what year is you car I am in UK as well I have grand voyager 54 problem with illumantion I just would like to know what year is you as far is i know in new model they are not replacable
please help
