-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   Identifying 30a fuse on 2005 grand voyager crd (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/identifying-30a-fuse-2005-grand-voyager-crd-22584/)
Seggelke Jul 22, 2014 09:05 AM
I have a blown 30 amp fuse hanging off the plus pole of the battery. It has burned pretty badly - the fuseholder has been blistered and the insulatio on one wire is melted.
I have no idea what this blown fuse is for.
goggs Jul 22, 2014 11:29 AM
How about tracing wire back to sourse. Is the wire bound in with the rest or standing alone. Just wondering if its a connection for Taxi appliences and the disconnected wire has earthed.
Seggelke Jul 22, 2014 01:31 PM
I was hoping to avoid tracing the wire as it could go anywhere - hence my post.
FWIW it is a green 30amp fuse.
tfb Jul 22, 2014 01:34 PM
what colour is/was the wiring either side?, can you post a picture?
Regards
Richard
Leedsman Jul 22, 2014 01:47 PM
You need to be very careful about "buckshee" wiring direct from a battery + terminal. No proper auto-electrician would ever do this as a fault could result in a fire destroying the vehicle. Insurance investigators would discover any buckshee wiring and possibly refuse to pay out. Fortunately the amateur electrician has at least put a fuse in circuit.
You should for your own peace of mind FULLY investigate ALL this wiring, and probably remove it. Getting an electric shock is impossible from a 12volt circuit, but starting a fire in a 12volt starter-battery circuit is very possible.
I speak as one who has lost a car (write-off) from this factor. It was a Citroen C4 and caused by the ABS unit under the bonnet/hood. Fault in that case was the manufacturer.
Leedsman.
Seggelke Jul 22, 2014 03:04 PM
Thanks all, here are two pictures
<iframe width="480" height="360" src="http://s1286.photobucket.com/user/se...how/"></iframe>
Seggelke Jul 22, 2014 03:07 PM
That did not go well. Are new members not allowed to edit posts or post pictures?
Trying again:
seggelke's Library | Photobucket
tfb Jul 22, 2014 03:11 PM
Hmm..that's not standard by any means. Remove the wire from the battery terminal to prevent any further chance of a short.
To find out what it was added for you'll have to hand trace the wire or find something that isn't working anymore.
Regards
Richard
Seggelke Jul 22, 2014 03:40 PM
Thanks, the only thing I am aware of that is not working is the AC cooling.
I was hoping I could just snip the wires and replace the fuse and fuseholder, but I think I will follow your advice, Richard, and disconnect it entirely. Quite the puzzle - fuse blown like no other yet pretty much everything works fine.
