installing new head unit for 01 t&c help
Hi, we have an 01 T&C LXI with the infinity system. Factory head unit stopped working and we bought a new pioneer and of course ran into a problem with the amps. Is there any way we can make this work without rewiring the whole thing? Already tried a new relay but if you can give explicit instructions on putting in a relay that would be helpful in case it was done wrong. Any help ASAP would be great, thanks!!
RE: installing new head unit for 01 t&c help
replace the front speakers they are the ones with the amps thay are built right into the speakers. DO any of the speakers work?
here is the rest of the setup fuse, relay, choke, and base speakers [IMG]local://upfiles/1033/ED35502FC78443D7997852319B02B689.gif[/IMG] |
All speakers are in working condition, there is just no sound due to the relay not working with the new head unit. Already had some instruction on bypassing old relay and putting in new one not in fuse box. Rear speakers appear to have amps too.
Hi
I am trying to fit an aftermarket dvd head unit to my grand voyager 2001> and everything works except the sound. I realise that it is something to do with the infinity speakers. When I took the original stereo out it had a grey and green wire connected to the back case labelled AMP. When I pull this off it cuts off the sound. What do I need to do to this wire to make the new stereo work, did you sort yours. |
| All times are GMT -5. The time now is 03:01 AM. |
