Seal Around Passenger Door
I am not sure if I am using the correct name or not. The black insulation around the passenger door is falling apart. I am afraid if I wait too long on this it might start leaking inside the door. I need to know if I am using the right terminology, because I can't seem to find replacement parts online anywhere. It's on the passenger door around the window and on the body of the van itself. I can take pictures if needed.
I think you are referring to the door seal? These should be easy to replace.
Thank you! Yes the seals. I couldn't think of the right word to save my life. I need to basically replace the seals on both the door and on the body of the van on the passenger door.
Does anyone know the part numbers for the 2 seals? I have tried searching several sites and can't find anything online. Is this a dealer only part?
Get a quote and the part numbers from a dealer and then go searching for those part numbers - that's what I do.
Does anyone know the parts numbers for the seals around the passenger door?
