internal lights and central locking Pls help!!!
Hi my name is Lisa and I have an 05 voyager, I searched this forum as I was having issues with internal lights. I came across a post suggesting the dimmer switch is the problem, sure enough the dimmer switch was indeed all the way up, rolled it back down and fab my lights now go off. BUT now my central locking doesn't work. Does anyone know of a way to get central locking working again please.
Thank you in advance Lisa |
Both key fob and door buttons dead? Remove the IOD fuse for 5 minutes. This will reset the BCM and data bus that control them.
Thank you so much it certainly did the trick
Lisa |
