Kay A Hartzell
I have a 2011 T & C and need to raise the rear body about 1" to keep the car level after it's loaded for camping and with the Camper hooked up. I can't find a 1" spacer to fit above the rear springs. Heavy duty shocks are installed. Any one have a fix instead of going to air shocks ?
email 88yakal2@mindspring.com
Easy if it's coil springs at back.
Get some of those hard rubber suspension ***** from a caravan/trailer shop and that will lift you up about an inch.
If you cant get them, use those hard rubber play-***** for dogs, available in sizes various.
With a hacksaw, cut some "V" shapes to keep the ball inbetween the spring's coils.
Done it many-a-time in the past. V. cheap and dead easy DIY. No dismantling, only jacking the car up as if changing a wheel.
Leedsman.
Leedsman.
