leaking coolant from passenger side front
ive noticed it a week ago. ive also notice its dripping down from were the belts spin on the passenger side of the engine :mad: i can see the drip but have no idea were its coming from it doesnt seam to be from the radiator hose on passenger side its coming from higher up. in side engine. can any one help :confused:
Year model and engine size? Mileage can be a help too.
Originally Posted by TNtech
(Post 54680)
Any place on the engine that has coolant going through it can leak Get it pressure tested to see where the leak is coming from.
Just an idea. Is it engine coolant or windshield washer fluid? I have a '97 Caravan, and an '05 T&C and the reservoir for windshield fluid is stuffed up in the right front fender / engine compartment. I've had leaks due to a 1> cracked container and 2> loose hose to rear sprayer. The container on the '97 is really buried and very difficult to see what's happening. You can see the bottle on the '08 from underneath.
Have 2006 with 90K miles. Coolant was leaking down the lower radiator hose. Triangle Dodge leak tested and replaced the water pump.
Leak
(Post 54680)
in gear not in gear would have nothing to d with a coolant leak. Did u feel what fluid what does it look like cold hot ?
| All times are GMT -5. The time now is 03:28 AM. |
