Lights do not flash when Alarm is set.
Hi this is my 1st day with my 1998 Grand Voyager and the only problem i am having with it when i lock the doors and the car alarms I get no indection of this NO chirp or Flashing of the Indicators.
Please can someone advise what is suppose to happen when the alarm is set please and also if there is something wrong where to start looking etc. Thank you |
I'm not sure this will help but from my U.S.A. 2000 FSM:
DESCRIPTION On vehicles equipped with the Vehicle Theft/Security System (VTSS), the doors, liftgate, hood and ignition circuit are monitored by the Body Control Module (BCM) when the system is armed. OPERATION The VTSS will prevent the engine from starting until the BCM receives a disarm signal. If the VTSS is triggered, the horn will pulse, headlamps/marker lamps will flash, and the VTSS warning lamp will flash. If BCM determines the threat to be false and the VTSS is not triggered again, the system will shut down and rearm itself after three minutes. The VTSS monitoring portion of the system is split into two sections. The engine compartment section and the passenger compartment section. If a malfunction occurs in the engine compartment section, the passenger compartment section would still arm and function normally. NOTE: If hood is not secure during the arming sequence, the lamp will stay lit and not flash. The system will arm with hood not secured (hood ajar switch closed). System will not arm if passenger compartment is not secure (all switches open) ENABLING To initialize the VTSS feature the operator must, with the engine compartment hood open, cycle the key in the liftgate key cylinder to the unlock position giving the BCM a disarm signal. At this time the visual alarm outputs the headlamps and marker lamps will function. However the audio alarm output the horn and engine disable portion of the VTSS will not function until there has been four consecutive engine run cycles. When this has occurred the total VTSS will function. If during alarm being set the BCM receives a request from the RKE module to enter PANIC mode the BCM will cancel the alarm, return VTSS armed state and then perform the RKE PANIC feature. My 2000 only sounds the horn when arming, i.e. no lights. I might experiment with the enabling section above to see if I can get the lights to flash also. |
I am having the same problem. I have a 2009 T&C Touring edition and I cannot find how to re-enable this feature. For a full year whenever you arm or disarm the alarm the lights would flash. I had the car is for yet another round of recalls and when I got it back the lights stopped flashing....
Any thoughts? Jay
Originally Posted by Katfish
(Post 48357)
