limp mode and other issues
i have a 2008 Chrysler grand voyager 2.8crd diesel auto. my problem is its stuck in limp mode. i've spent a £1000 on it up to now. i took it in a garage 2 weeks ago, where it was 4 days. they told me its not worth fixing and would be cheaper to buy another car. i don't accept that. they did the cluster repair for me in november. it cost me £300, to get the engine management light off and the abs light. now there back on and its showing up various faults on it. a cluster fault, LF / RF wheel sensor signal fault. Valve power feed failure. codes p0700 and p0725. 9x theft alarm module codes. 36 missing sensor rear, 26 missing sensor LF. 31 open sensor RR. 21 open sensor RF. 4x UNKNOWN. internal failure 38 wheel speed error. 73 inoperative watchdog inhibit. 71 ram incident. 8 power sliding door module- left codes. 84 mismatched vin. 69. excessive dump. 6x unknown and 7x unknown. 52 open dump coil rear. 51 open iso coil rear. 42 open dump coil RF AND UNKNOWN 26. any help, from you would be appreciated. also if you direct me, to what parts i would need, to get it up and running again. i am disabled and have serious neck and back problems. also bowel and other problems too. so if its not too hard to fit or do, i will try and give it a go. i was a car and bus mechanic many years ago. but these cars I'm not clued up on. when it comes to electrical. thanks for reading |
