Locking Wheel Nuts...
Hi guys, Was just going to sort out my rear brakes Caliphers where the pistons are still sticking. Jacked up and placed on stands, tested wheels and the're dragging...Wheels off...yes and no....seem to have misplaced my locking wheel nut tool/key of which I had only one....Weekend repair waisted or what..
So guys I take it, its Chrysler for a replacement key/tool... Or I'm thinking of removing locking nuts with a removal tool and replacing with ordinary nuts. Any of you's recommended a locking nut removal tool. Prob will need to find scrappie for 4 nuts as well... Goggs... |
depending on what type of locking nut and clearance around it, I've had some luck just hammering an old socket over the top of the nut. Drilling out can be a bit of a sod to do as it's hard to keep the drill centred and not damage the wheel.
Regards Richard |
Locking Wheel Nuts.
Hi again. As usual forgot to mention cars a 2003 Grande Voyager CRD LTD.
Yes tfb you have the thoughts that come to us all, knocking on a heated socket came to me too, but well the wheels are not supposed to be able to be removed without this key/tool. Machine Mart have a locking wheel nut removal tool which by looking at them come as a set of left hand screwed nuts to go over the locking nut. Do they work, I've no idea, they are reminicent of some stud extractors which might be better. Should have taken a note of the numbers of my nut tool the last time I used it, as at one point I thought a might need it some day. Heres a picture of the nut anyway. Goggs. |
Locking Wheel Nut Picture.
1 Attachment(s)
Hi lets try again for a picture.
Originally Posted by goggs
(Post 70012)
- if you have the original invoice for the security bolt purchase most Thatcham approved ones had a re-order security code number - if you ask 10 mates if you can try their security socket the odds are you might find one that's identical - as 'tfb' said most fitters brae on a socket and long bar it off - always a risk, but 99% do it Best of luck |
Hi, cars left on stands, wheels turn with drag. Working away and using my trusty 2.1TD Espace at mo...Definately no comparison.
Looking into getting replacement key/tool or swaging on a 17mm bore steel tube as thats the route size of the wheel nut. Will keep you's all posted next weekend.... Goggs.. |
(Post 70023)
Looking into getting replacement key/tool or swaging on a 17mm bore steel tube as thats the route size of the wheel nut. Will keep you's all posted next weekend.... Goggs.. - if you live anywhere close I have some, - brutal - but effective - might need to recut the thread when done |
Hi To Date, new set of locking nuts and key ordered via Chrysler main dealer, £24 odds. Intension is to hire locking nut extractor from my MOT/Repair garage...
God all this because I've mislayed/lost this key tool..And bet I'll find it some day... Goggs.. |
(Post 70097)
Hi To Date, new set of locking nuts and key ordered via Chrysler main dealer, £24 odds. Intention is to hire locking nut extractor from my MOT/Repair garage...
God all this because I've mislaid/lost this key tool..And bet I'll find it some day... Goggs.. |
| All times are GMT -5. The time now is 03:09 AM. |
