Loose exhaust manifold bolts
Old May 31, 2010 | 08:54 PM
rhino's Avatar
Default Loose exhaust manifold bolts
Last summer I noticed my van started to sound like it had a bad lifter. After opening the hood I had seen it was a little black around the exhaust port closest to the trans. I grabbed the head of the bolt it was way loose, both of them were. So I checked all of them and the bolts were loose on the other side closest to the trans. I checked them today and they were loose again. Why would the same bolts come loose all the time? Is this a regular issue because of the heating and cooling cycle it goes through?
Old Jul 23, 2015 | 08:29 PM
eldeliaj's Avatar
Default Same issue here
Hey, I know this is an old thread, but on my 2000 T&C I noticed same thing, exhaust manifold bots closest to transmission were loose
Then more recently I got a 2002 T&C and the same issue... this is pretty bad, loosing faith on these cars
I can only assume because they're closest to where all the movement in the exhaust system happens that they get loose eventually. May have to use some type of that blue liquid for threads but idk if that stands up to high temps.
This has to be a wide-spread issue, and people just not noticing it - and I'm surprised if it's not a recall for these
purplepuller
Oct 26, 2014 07:32 AM
G Bender
Oct 8, 2013 01:20 PM
OldGunz
Sep 2, 2013 11:54 AM
Cliff250
Feb 11, 2012 01:58 AM
onecheck
Mar 4, 2011 08:40 PM
