Loss of Power 2005 Chrysler Town & Country Touring 3.8
Old Oct 14, 2016 | 10:08 AM
BARKWOOD's Avatar
Default Loss of Power 2005 Chrysler Town & Country Touring 3.8
My 2005 Chrysler Town & Country is having problems with MAP, TPS correlation. I have replaced both but still have code P0129, P2074 come up. I know one reads that it could be caused by a vacuum leak. I have used starting fluid to find the leak with no success. The van will run but after getting warmed up, it will start to lose power when taking off. I have to adjust my pressure on the gas pedal before it catches on. I don't know where or if there could be a leak...could it be the PCV valve (getting stuck open or something)? I know it's not the PCV hose because I replaced it because of a crack. I haven't changed the PCV since I purchased it in 2009.
Your help is appreciated.
Barkwood
Old Oct 14, 2016 | 09:06 PM
get a volt meter and meter al 3 wires at the amp and tps tel me what the numbers are with the key on
Old Oct 20, 2016 | 07:57 PM
BARKWOOD's Avatar
Default Thanks...found the problem
Thank you for your response. I ended up taking it to the Chrysler Dealership that couldn't find the problem. They said I must have a short to ground somewhere after keeping my car for 3 days...and charging for additional diagnostics. They said the hand tool wasn't picking up communication. They supposedly went through half of the modules and didn't find the problem. Sorry, got long winded...but another auto repair shop, with the same information I gave Chysler, found the problem within a day and fixed it for less than what Chrysler charged. At any rate, the problem that my signal wire to my map had a short/burned/frayed. They repaired it. Problem Solved.
Once again, thanks.
Barkwood
wis2ohio
9
Dec 4, 2013 09:11 PM
jaco
Apr 9, 2010 11:41 AM
jblanco
Jan 11, 2009 05:49 PM
zippppy1
Jul 5, 2007 11:47 AM
zippppy1
Oct 5, 2005 03:34 AM
