-   Chrysler Voyager & Town & Country (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/)
-   -   Macpherson strut (https://www.chryslerforum.com/forum/chrysler-voyager-town-country-21/macpherson-strut-21994/)
sundowners May 13, 2014 08:47 AM
Macpherson strut
Hi
My front macpherson strut has pulled out of the top mount assy--------I have ordered a new top assy (and spring compressor)--------Does anyone know if I can get the strut back in place without removing it from the bottom, or do I have to take it right out to get it back together ???---------Thanks for ANY suggestions on this repair
Nigel
CHRYSLER TECH May 13, 2014 10:01 AM
U will need to take whole assembly out for any repairs. Me personally I would do a quick strut while assembly.
sundowners May 13, 2014 11:06 AM
Hi
Thanks for that, BUT I tried to get a 'quick-strut' but they seem to be unavailable in UK-------I have had another look at it and realise that it all has to come off------I have now got everything loose awaiting a spring compressor and the top kit-------the shock and spring look good enough to re-fit;):)
Nigel
tfb May 13, 2014 01:03 PM
I've got a spring compressor you can borrow, can drop it off on my way into work tomorrow night if you like.
Regards
Richard
goggs May 13, 2014 01:59 PM
Past threads on here reported about problems removing these springs, even by garages. Is there a special compressor required.
goggs May 13, 2014 02:29 PM
Ahh, all is in P44cmb Front Suspension Woes 09-16-2013....Terrible that even Chrysler garages had a problem..
pob May 13, 2014 04:38 PM
I tried to change the top bearing on my car; my standard spring compressors couldn't get enough pressure into the spring. I had to use a ratchet strap aswell as the compressors to get the top mount on.
sundowners May 13, 2014 05:58 PM
Regards
Richard
Hi Richard
You are a star----but I ordered a set today, they should turn up along with the top mount tomorrow (wed)----------reading the last couple of posts it looks like it might not be straight forward.
I am interested in a code reader though :(--------I don't think I would be able to work the one you have:o:o ----looking for one a bit simple :)
Nigel
sundowners May 14, 2014 04:34 PM
Update on front strut-----
I ordered the top mounting plate and 'bearing' yesterday PM-----and a (cheap) set of spring compressors-----------they arrived by lunch-time today.
The spring compressors would not get the spring short enough in one bite so I also used a G clamp-----got the spring out OK and had quite a nerve-wracking time getting the spring short enough to put the strut back together----eventually used two small ratchet straps as well.
Now all back together and OK.
The job was easier than I expected-----but it helps a lot to watch the operation on U tube first :D
I would strongly suggest at least three spring compressors----make the job easier/quicker/safer ;)
So now I am waiting for the other side to go :rolleyes:
If I had known how easy it would be I would have bought parts for both sides ;)
Nigel & Pamala
sundowners May 14, 2014 04:39 PM
Hi
I understand exactly what you mean---------I would have liked at least one more spring compressor---------I also used two small ratchet
Nigel
