MAF sensor
hi guys can someone help me out here please , 2 questions 1, does the MAF communicate with the ECU so if it faulty the ECU will know , and 2 does any one have a diagram of the wiring plug and info on the voltage at each wire
The MAF is connected to the ECU.
Fault finding and connector info can be found here http://oskin.ru/pub/chrysler-dodge/m...Powertrain.pdf Wiring diagrams can be found here https://drive.google.com/open?id=0Bw...TdfQldWeUZXZ0k Regards Richard |
thanks , I just had a chap here he hooked his machine up to it and it says no MAF available
Originally Posted by tfb
(Post 94290)
+5V supply from the ECU.
I think the "no MAF available" may be a problem with the scan tool. If there is no reading from the MAF then an error code would be logged. Was he trying to look at the live data? |
yes mate he had a little machine hooked up with the engine running
