Many problems in my 2001 Chrysler Town and country, any help is appreciated....please
I've recently bought a 2001 Chrysler Town and Country Mini van LXI with 134,000 miles. I think I made a huge mistake. The drivers window stopped rolling down, the abs, brake and traction off lights stay on 90% of the time, the anti theft system is activated when going in any door other than the drivers door first causing the van not to run, at times when using the radio controls the volume wont turn down but up instead and the cd player can only be controlled by the steering wheel buttons, and now the front blower has completely stopped working. Any suggestions to any of these problems is greatly appreciated! I am regretting buying this thing already, very frustrated!! Thanks.
> Driver's window - Most likely the motor. You could change the motor or just the brushes. In the long run it's best to change the whole window regulator assembly. Could be the switch. In the mean time open the door, hold the switch down then slam the door shut. This will sometimes bring a motor back to life.
> ABS, brake, traction lights - Probably a wheel sensor but need to connect a scanner capable of reading ABS codes to narrow down the problem. Inspect connections and harness at each wheel.
> Anit-theft - Long shot but try disconnecting the negative battery cable for 5 minutes. Might reset the system. May need to be reprogrammed.
> Radio - Replace it
> Front blower - Check fuses in the IPM (fuse box). Swap the front blower relay with an identical relay on the panel. Check voltage at the blower motor connector (behind glove box). If you see 12vdc with the switch on high change the blower motor. If not, change the blower controller (left of motor).
> Radio - Replace it
Town & Country power sliding door won't open or won't open all the way - YouTube
Does the hatch lift supports need replacing?
GODFATHER
Apr 12, 2015 08:44 PM
stinkytofus
Oct 7, 2013 09:57 PM
