Matching parts
Hi
I was coming down a hill near us yesterday morning and slid on the snow into a telegraph pole. Luckily not going fast so it only seems to be a smashed bumper a dented bonnet and a bend to the front bumper support bar. I've got a 2003 2.5 crd, and have found a 2001 3.3 petrol which is breaking for parts with a good front end, both 4th generation. Does anyone know if the parts will match? There's also a slight bend in the radiator - try to get it flat again, leave it or get a new one, its not obviously leaking, the temperature's fine, but there is now a little hissing noise after a journey when i've checked under the bonnet. Many thanks. |
The bumper, bonnet and such probably match. As far as I know those parts are all the same as long as its same Gen.
You sure it is the radiator which is bent or potential leaking? I smashed in another car and broke my AC condensor located in front of the radiator. Probably its your AC which is hissing and probably not working anymore :) |
Thanks for that, I was pretty sure that they would match but not 100% sure!
If it is the air con I'm not too worried about that at the moment, but I've sourced a £25 radiator from a breaking Chrysler with back end damage just in case. Since I'm taking off the front end anyway I'll have it if needed! |
See if you can get the condenser from that broken Chrysler too.. to be sure :cool:
