motor tap
I have a 2000 Town and Country, 3.8 engine. When the engine is cold there is a tap, sounds like from the top, it only does this when the motor is cold, once is war there is no noise. What is causing this?
low oil or lifters not having oil up top its basically a lifter not being pumped up.
oil level is good, so a new oil pump?
Did i say anything about an oil pump??
AN oil pump does not get batter as it warms up U have a lifter issue or an oil filter not allowing oil to stay at the top of the engine |
how would a oil filter get better as the motor warms up
Wynns Hydraulic Valve Lifter Treatment
throw in a bottle of that,that will help cure it.will clean all the oil ways |
Originally Posted by merrellj
(Post 57973)
This would be the 3rd time I have pointed out this is a lifter prob and things like cheap oil filter low oil or a bad lifter could be the cause to this issue Please read the info I have given and think about what U ask or say b4 U post it.
Thanks brroke23 I hate repeating myself more then 2x |
