My chrysler town and country will not start
I have a problem with my 2004 Chrysler town and country. To start with it was running rough, but then one day it was running rough and then it all of a sudden just died and it won't start now. I have replaced the ignition coil, I have replaced the spark plugs, and I replaced the fuel pump. The spark plug wires I think have been recently replaced. I am at a loss don't know what to do next.
Did the check engine light ever come on while it was running? If so do the "Key Dance" and it will show what the computer is NOT liking to help narrow down the problem.
Turn key from off to run position (dash lights come on, NOT starter crank) 3 times within 5-10 seconds, on the 3rd time leave in the run position.Code(s) will display where the mileage reading is.and when complete will display the word "done"and then a series of dashes. A code will start off with a "P"followed by a 4 digit number, WRITE IT DOWN and post it here.
OK, here we go! have you already looked the codes up on your own? IF NOT the following are
P0627..Open or shorted condition fuel pump relay control circuit
P0685..Open or shorted condition in automatic shutdown relay control circuit
P0688..automatic shutdown relay control circuit low
P0113..Intake air temp sensor input above max acceptable range
You have either FRIED wiring or bad engine fuse panel where all the wires plug into the bottom of it. unbolt and lift the fuse panel assy and check wiring there.
With the codes listed, no amount of PARTS will make it start with the ELECTRICAL controls not working. Has this gone thru a flood or accident???
Burned , corroded, or broken wire ends at the harness plugs going into the bottom of the fuse panel mounted on the drivers side in the engine compartment. If that does not show any problem, then you most likely have a bad fuse panel. You are not in a plug and play situation here, you need to inspect and repair wiring problems.
