My heater or A/C only works on full blast.
Old Jan 11, 2008 | 08:22 PM
3.3lxbluevan's Avatar
Default My heater or A/C only works on full blast.
I have a 2001 T@clx and the heater or A/C only works in full blast and the **** works on full blast. I know It's some kind of a fuse or sensor It's inside the **** area. How can I go ahead and take out the bad fuse or sensor. Thanks.
Old Jan 12, 2008 | 12:32 AM
Default RE: My heater or A/C only works on full blast.
blower motor resistor power module
Old Jan 12, 2008 | 01:39 AM
Is there any DIY instructions so I can take care of It.
Old Jan 12, 2008 | 07:15 AM
CAUTION: Do not operate the blower motor with the blower motor resistor removed from the circuit. Failure to take this precaution can result in vehicle damage. [ol][*]Disconnect and isolate the battery negative cable.[*]Open the glove box.[*]Flex both sides of the glove box bin inward near the top far enough for the rubber glove box stop bumpers to clear the sides of the glove box opening, then roll the glove box downward.[*]Reach through the glove box opening to access and disconnect the instrument panel wire harness connector for the blower motor resistor from the resistor connector receptacle (Blower Motor Resistor).[*]Reach through the glove box opening to access and disconnect the blower motor pigtail wire connector from the resistor connector receptacle.[*]Remove the two screws that secure the blower motor resistor to the evaporator housing.[*]Remove the blower motor resistor from the evaporator housing. [/ol]
[IMG]local://upfiles/1033/3C597D25E9D0455C9000622279F9D3E3.gif[/IMG]
Old Apr 16, 2008 | 09:09 AM
dblcruzin's Avatar
is this the same instructions for 2001 sebring conv?
have same prob
Old Apr 16, 2008 | 01:09 PM
pretty close same side but this is on a mini van not a car.
Old Apr 16, 2008 | 03:46 PM
moe's Avatar
moe
number #1 is blower resister on sebring.don't get dizzy holding your head upside down![&:][&:]
courtney frias
Apr 13, 2012 11:15 PM
mstjohn1974
Jan 14, 2012 10:54 PM
GTC12987
16
Nov 19, 2010 10:56 PM
IceBoy
Feb 12, 2008 10:44 PM
tomulis221
Dec 18, 2007 03:34 PM
