MY05 console led replacment.
Hi guys, I have search in the forum but I have not found about this console led replcement for a 2005 MY.
Does someone knows the correct led type for the replacement? Is the led for the buttons light in the upper console. Thank you in advance. https://s3.postimg.org/v0008mjpf/20160819_184831.jpg https://s3.postimg.org/zaeo47osj/20160819_184904.jpg |
Hi there,
Believe it or not, that IS NOT an LED, it's a regular tungsten bulb with a blue rubber cover over it! I've replaced quite a few of these now and i do replace them with LED. The main problem/difference is that an LED doesn't diffuse light in the same way, it's a lot more targeted, so you either need an LED with very wide beam or replace with a regular panel bulb. Search ebay for rectangular LED and you should fine what I've used in the past: https://lh3.googleusercontent.com/7k...4CF7H0=s225-no Hopefully that'll help. Oh and a word of caution, the boards and circuit traces are VERY fragile, I've had to re-make a lot of them with replacement wires because as soon as the soldering iron touches them to remove the old bulb the traces peel off the board and fail. |
Tks a lot Andy!
very clear and detailed explanation! Ony the attached pic not works.. if you can post it again when you have some free time.. Tks a lot. |
1 Attachment(s)
Ah apologies, try again for the image:
Attachment 2376 |
changed with a new tungsten but bulb without the blu cap.. the light is better..
rebuilt the two circuit boards.. now it works ok! tks Andy |
