Need help to replace clutch
Lyon FRANCE
I have a 1991 Chrysler Voyager with a 2.5 petrol engine and 5 speed manual transmission. The clutch & pressure plate need replacing. If anyone has a workshop manual for this model can they please email me the section showing an exploded view of the clutch. Many thanks |
This job is very straight forward. I have step by step proceedures in a shop manual but no way to post it and I'm not about to take the time to write it all out. I suggest you just get a shop manual so you have all critical information and torque specifications.
In summary: disconnect battery remove starter remove axle shafts disconnect clutch and shifter cables remove transmission mount and stabilizer strut on back of transmission remove bellhousing bolts remove the transmission to install, reverse disassembly proceedures The exploded view of the clutch is basically the exact same as any other vehicle clutch assembly.. |
Thank you for your reply.
| All times are GMT -5. The time now is 04:27 AM. |
