Need Help - Town and Country Won't Start
Hi, I have a 2005 Chrysler Town and Country Limited 3.8L. The other day my wife called me from her lunch break and said that Check Engine light came on, and a second later it started running really rough. I took her my vehicle so that i could drive the van home and check it out ( i only live a few miles away). I checked the code and it was showing a P2302 and a P0300. I started driving it home to check the plugs and test for spark, but then it died on my way home. After it died (in the intersection) it would not start again. it would click, but that is all. I ran the ODBII again and got a code P0480 cooling fan circuit. After i towed it home, i replaced the ignition coil pack and plugs, but that did not help, and the OBDII was now reading a P0700 TCS malfunction. Now it will not even try to crank. I checked and there is no ground to the starter relay. I made a jumper ground to the relay and it cranks, but does not fire or turn over. I'm thinking maybe its the PCM, but not sure. Any ideas?
mark_gober
14
Aug 19, 2012 10:22 AM
roykaren
Jul 15, 2010 08:18 PM
rcenturion
9
May 12, 2008 11:02 PM
