Newbie needs rad fan help!!!!
Got my first GV after getting rid of my Grand Cherokee. I took the GV for a long drive to check temps because the guy who traded it in said that somethings not right with it because the fans dont kick in.
I have bridged the grey/dark green on the fan relay (under the airbox) and both fans work. The worrying thing is that the bridging wire (paper clip) got extremely hot. I would imagine the relay is shot but I dont want to replace if the heat created through the wiring causes heat because it could knacker the relay. Any ideas would be of great use |
From the 2000 FSM:
INSTALLATION CAUTION: The relay mounting location is designed to dissipate heat. Ensure the relay is properly attached to prevent relay “thermal” shutdown and relay damage, resulting in possible engine overheating. I seem to remember reading somewhere you need to clean the relay mounting area and use a heat transfer paste between the relay and the mounting area before riveting the new one. |
