Next Step...P0500
3.3 Engine light after speedo quit, got codes P0500, P1495, P1684, transmission smooth, replaced both input/output sensors, still get engine light with error codes . Battery 12.4 any suggestions? :confused:
.....this is on a 2001 T&C
P0500-no vehicle speed signal (4sp auto trans)
possible causes intermittent condition vehicle speed sensor signal shorted voltage vss signal from tcm vehicle speed sensor signal shorted to ground vehicle speed sensor signal open pcm vss signal p1495-leak detection pump solenoid circuit |
thanks for the quick reply CT,done what I could,hoped it was a sensor,looks like it's shop time.No idea and not gonna ask how to check pcm/tcm. Leave it to the diagnostic gurus.
| All times are GMT -5. The time now is 06:46 AM. |
