No rear blower fan and stuck window in 00 Voyager
2000 Voyager SE (AU)
The rear window (pop out corner) is stuck open and won't retract when pushing the button. (The other side doesn't work either.)
I tested it by hooking it directly to a 12v supply and it works fine.
I cannot after looking over the fuse box work out which fuse actually covers these windows.
And whilst I was there I noticed the squirrel cage motor that blow air for the rear passengers was seized - that would explain no air in the back. I popped off the 4 pin connector and couldn't read any voltage in any combo which makes me think fuse again.
Its about time I got a service manual I think!
Any help would be greatly appreciated. Once I solve the electrical mystery I might have a crack at pulling out the fan motor and seeing if the bearing can be repacked / windings aren't shot.
Cheers, Antony.
Cheers, Antony.
Numanchi
Aug 26, 2011 06:40 PM
3.3lxbluevan
9
Dec 10, 2010 07:17 PM
