noise in engine compartment
Old Aug 12, 2013 | 09:38 AM
wd4fcj's Avatar
Default noise in engine compartment
2003 town and country
noise at idle like a bad pensioner bearing or idler pully bearing . i have checked and replaced the belt and the tensioner ,i have checked the idler pully and the a/c compressor bearing, the water pump and pulley bolts. noise goes away off idle. i worked for GM dealer for some 30 years and it sounds like crank pulley bolts loose. or a dry or cracked belt. these items have been replaced or checked.possible its in the power steering area. but its not a mone or whine or squeel .. i also removed the resovoure and cleaned the filter screen and replaced the fluid. got me stumped
Old Aug 12, 2013 | 11:27 AM
georgef's Avatar
It might be the "Alternator Decoupler Pulley" check out this post: Two noise but not sure what they are from.
George
Old Aug 13, 2013 | 03:29 PM
wd4fcj's Avatar
i believe you are right. checked it out and seems to be the problem. thanks for your help. been messing with this for a couple weeks. using a stethoscope i could not find the problem. thanks again Richard
Old Aug 14, 2013 | 11:05 AM
georgef's Avatar
You're welcome.
George
Old Aug 16, 2013 | 03:15 PM
VVVVVVVVVVVVVVm's Avatar
Had the same on my multipla, replaced the clutch pulley and it carried on lol.
Sold it.
sea doo
Feb 3, 2012 04:31 AM
Cdave
May 22, 2010 02:16 PM
jbauman
Dec 15, 2008 04:17 PM
jbauman
Dec 14, 2008 09:53 PM
choprpilot76
Nov 2, 2007 01:49 PM
