noise in engine compartment
2003 town and country
noise at idle like a bad pensioner bearing or idler pully bearing . i have checked and replaced the belt and the tensioner ,i have checked the idler pully and the a/c compressor bearing, the water pump and pulley bolts. noise goes away off idle. i worked for GM dealer for some 30 years and it sounds like crank pulley bolts loose. or a dry or cracked belt. these items have been replaced or checked.possible its in the power steering area. but its not a mone or whine or squeel .. i also removed the resovoure and cleaned the filter screen and replaced the fluid. got me stumped |
It might be the "Alternator Decoupler Pulley" check out this post: Two noise but not sure what they are from.
George |
i believe you are right. checked it out and seems to be the problem. thanks for your help. been messing with this for a couple weeks. using a stethoscope i could not find the problem. thanks again Richard
Originally Posted by wd4fcj
(Post 72530)
George |
Had the same on my multipla, replaced the clutch pulley and it carried on lol.
Sold it. |
| All times are GMT -5. The time now is 03:09 AM. |
