odometer & gear selector LEDs do not work on startup - 07 Town & Country
I have recently purchased a 2007 Town & Country. I have an intermittent problem on startup, the odometer and gear selector LEDs do not light up. Sometimes they turn on after a minute or two, but today my wife drove it and the LEDs did not light up until she was almost home (about 10 miles). Most of the time they work as they should. Has anyone else ever heard of this?
Originally Posted by Hawgfan
(Post 81254)
I couldn't say for sure, however this sounds like a connection issue based on the symptoms you've described. Have you noticed the lights turn on/off if you are driving over any bumps? If needed, I would recommend getting your T&C over to a Chrysler Service Facility for an inspection. |
Both are powered by the same internal circuit inside the instrument cluster and controlled by the data bus.
> You could try a data bus reboot by disconnecting the negative battery cable for 5 minutes. If your radio has a security code have that handy to reactivate the radio. > Not sure if this works on an 07 but try a cluster self test. Hold in the knob on the cluster then turn the key to on. Within a few seconds the odometer should say Sof etc. Release the knob. The digits and indicators should cycle through a self test. Make sure the odometer and PRNDL work. This could reset a dodgy (yup that's a pun) circuit. > If you're game you code remove the cluster and closely inspect for any bad solder joints on the circuit board. > Could be a first sign of a weak battery. Make sure the connections are clean and tight. Have it load tested - free at most parts stores. |
odometer & gear selector LEDs donot work on startup
Thanks for the replies. The answer to the problem was explained in the owners' manual. We have had a lot of rain here lately in western AR and I remembered that the LEDs did not work when I was using the wipers. The wipers on this vehicle also activate the headlamps, which also activate the dash lamps. One of the first settings I made when I drove this car was to turn the dash lamps to about 1/2 their brightest intensity, and when the headlamps are turned on during the day that makes the dash lamps appear to be off. So there is nothing wrong with anything, I just had not read that part of the manual yet. I will just get used to the dash lamps at their brightest setting and I will be able to read the gear selector during the day when the wipers are on. By the way, we both really like this van. :D
Like to hear those easy "fixes".
