Outside Temperature
Hi,
I have a 1999 Grand Voyager and my outside temperature reads 0 degrees at all times. I wondered if anyone knows:- 1) Where is the sensor for the outside temp 2) What might cause it to read 0 degrees all the time? Is it simply unplugged? Thanks Mike |
Hello from U.S. my 98 has the sensor located behind the bumper cover,down low, in front. I can see it if I look thru the lower part of the cover. If I remember correctly to get to it requires un doing the bottom of the cover, pull it forward and you will see the sender and the plug that goes to it. Hope this helps.
Yeah, thanks I have changed it now. I just used a socket and extension bar to get onto the bolt from the front of the car.
Thanks Mike |
