Please..... help my rear window wiper and rear washer has stoped...
Hi, everyone I am having a dillemma with my van lately, I have been working around the van and trying to keep it up to date as possible, but the rear wiper and the washer has stopped working. I checked the fuses but that did not fix anything. I want know what else can it be, can It be the motor and If so where Is It located. HELP A.S.A.P.
The motor is located right at the base of the wiper. They don't last forever. Check your local parts store for an aftermarket replacement. It's not a big deal to pull off the interior trim panel and get the old one out. I was able to do it on my old '95 Voyager with a couple of hour's work.
(Post 26996)
Does the washer have some kind of a senor to sence the motor not working and so the washer stops to. |
what year van do u have?
(Post 26998)
huh? what are u talking about
(Post 27061)
being that its aftermarket I have no idea how to wire it up
To side w/ Chrysler Tech, I was confused by the brief mention of a motor too. You cleared it up better w/ your second reply. You left out a little more detail.... did the motor come w/ install directions? How did you know what to wire? Did you get it from a place you can ask how it is wired? Do you have a wire diagram for the car so you can tell if power is actually going through the right wires when motor is told to be on via the switch?
I have the same problem, well a few more but this one for sure. I took everything apart and i also applied 12vdc to the motor and it works. The switch also lights up when i push it on the dash. I am thinking bcm. Does anyone have any input. Thanks
