power locker problem..
Old Jan 23, 2008 | 06:03 PM
jquinones's Avatar
Default power locker problem..
Good evening pros,
I have 01 T&C AWD and power locker on driver side it’s not working from inside or remotely, then I have to lock manually.
Does anyone have any idea of what should I do?
Thank you guys.
Old Jan 24, 2008 | 08:40 AM
Default RE: power locker problem..
if no locks work nore the remote I would say the BCM is faulty
Old Jan 24, 2008 | 01:11 PM
jquinones's Avatar
BCM?
Old Jan 24, 2008 | 02:10 PM
body computer
Old Jan 24, 2008 | 02:43 PM
jquinones's Avatar
easy to solve?
can I do myself?
thanks pro
Old Jan 24, 2008 | 11:10 PM
REMOVAL [ol][*]Disconnect and isolate the battery negative cable.[*]Remove the lower instrument panel silencer.[*]Remove the knee blocker and reinforcement (Refer to 23 - BODY/INSTRUMENT PANEL/KNEE BLOCKER REINFORCEMENT - REMOVAL).[*]Disconnect the five wire connectors from the bottom of the Body Control Module (BCM).[*]Move bulkhead wiring aside.[*]Remove the screws holding the BCM to the bulkhead.[*]Remove the BCM from the mounting bracket[/ol]
REMOVAL [ol][*]Remove lower steering column cover (Refer to 23 - BODY/INSTRUMENT PANEL/STEERING COLUMN OPENING COVER - REMOVAL).[*]Remove the park brake release handle link from the park brake release handle.[*]Remove screws attaching lower steering column backing plate to instrument panel (LOWER STEERING COLUMN COVER).[*]Unclip the Data Link Connector (DLC) from the lower steering column backing plate.[*]Remove lower steering column backing plate from vehi[/ol]
Old Feb 1, 2008 | 01:19 PM
jquinones's Avatar
I'll try
Old Feb 2, 2008 | 11:30 AM
jquinones's Avatar
I did take a part, easy,and I can see that its rust and bad shape the part.
How much is a new one? do you have part number? I know its 4 numbers and letter R (****R)
thanks
Old Feb 11, 2008 | 05:29 PM
jquinones's Avatar
this BCM you talking about it is the one that goes inside the door right? the one responsable to lock and unlock the door right?
It has aplug connect to it with4 wires (if I remember right)connectedand looks that this part is rust and stuck, the wires have voltage I check it when the buttons are pressed to open or close.
do you know how much it could cost thi new part? do you have part number and wheres the best place and good price to buy it?
thanks
Old Feb 11, 2008 | 05:58 PM
only one BCM and I told U where it was plus instructions U also did not say if it was only the driver door or all of them.
