preset setup
Hi all I hope one of you can help me, a friend has recently purchased a 2000 grand voyager and didnt get a handbook with it,the question I have is how to setup the unique seat/mirror position to the individual key fobs. The situation now is everytime he and his wife unlock the door with the remote the seat and mirrors adjust to differant positions, both not to their reqirments. Any advice given to either set up this up or disable it will be very appreciated.
And a good christmas to all here. Joe |
RE: preset setup
Suggest they exchange key fobs. One fob is usually linked to memory positon 1 and the other to position 2. The 2004 Town and Country is similar to the 2002. The owners manual can be downloaded for free from Chrysler here:
http://www.chrysler.com/en/owners/manuals/index.html From the owners manual: DRIVER MEMORY SYSTEM — IF EQUIPPED Once programmed, the memory buttons 1 and 2 on the driver’s door panel can be used to recall the driver’s seat, driver’s outside mirror, adjustable brake and accelerator pedals, and radio station preset settings. Your Remote Keyless Entry transmitters can also be programmed to recall the same positions when the Unlock button is pressed.Your vehicle may have been delivered with two Remote Keyless Entry transmitters. One or both transmitters can be linked to either memory position. The memory system can accommodate up to four transmitters, each one linked to either of the two memory positions. Setting Memory Positions and Linking Remote Keyless Entry Transmitter to Memory NOTE: Each time the SET (S) button and a numbered button (1 or 2) are pressed, you erase the memory settings for that button and store a new one. 1. Insert the ignition key and turn the ignition switch to the ON position. 2. Press the driver door memory button number 1 if you are setting the memory for driver 1, or button number 2 if you are setting the memory for driver 2. The system will recall any stored settings. Wait for the system to complete the memory recall before continuing to step 3.3. Adjust the driver’s seat, recliner, and driver’s side view mirror to the desired positions. 4. Adjust the brake and accelerator pedals to the desired positions. 5. Turn on the radio and set the radio station presets (up to 10 AM and 10 FM stations can be set). 6. Turn the ignition switch to the OFF position and remove the key. 7. Press and release the SET (S) button located on the driver’s door. A chime will sound signaling that you are in the memory set mode. 8. Within 5 seconds, press and release memory button 1 or 2 on the driver’s door. A chime will sound signaling to you that the driver memory has been set. The next step must be performed within 5 seconds if you desire to also use a Remote Keyless Entry transmitter to recall memory positions. 9. Press and release the LOCK button on one of the transmitters.Achime will sound signaling to you that the transmitter has been successfully linked to memory. 10. Insert the ignition key and turn the ignition switch to the ON position. 11. Select 30 31Remote Linked to Memory9 in the Electronic Vehicle Information Center (EVIC) and enter 44[/size]45Yes9 [/font]or select 58[/size]59Use Factory Settings9 from the EVIC and enter [/font]9 Yes71[/size][/font]72. Refer to the Customer Programmable features in the Electronic Vehicle Information Center (EVIC) section for more information. 12. Repeat the above steps to set the next memory position using the other numbered memory button or to link another Remote Keyless Entry transmitter to memory.Memory Position Recall NOTE: The vehicle must be in Park to recall memory positions. If a recall is attempted when the vehicle is not in Park, a message will be displayed in the Electronic Vehicle Information Center (EVIC). To recall the memory settings for driver one, press memory button number 1 on the driver’s door or the Unlock button on the Remote Keyless Entry transmitter linked to memory position 1. To recall the memory setting for driver two, press memory button number 2 on the driver’s door or the Unlock button on the Remote Keyless Entry transmitter linked to memory position 2. A recall can be cancelled by pressing any of the memory buttons on the drivers door during a recall (S, 1, or 2). When a recall is cancelled, the driver’s seat, driver’s mirror, and the pedals stop moving. A delay of one second will occur before another recall can be selected.To Disable A Transmitter Linked to Memory 1. Turn the ignition switch to the OFF position and remove the key. 2. Press and release memory button number 1. The system will recall any memory settings stored in position 1. Wait for the system to complete the memory recall before continuing to step 3. 3. Press and release the memory SET (S) button located on the driver’s door. A chime will sound signaling that you are in the memory set mode. 4. Within 5 seconds, press and release memory button 1 on the driver’s door. A chime will sound signaling to you that the driver memory has been set. 5. Within 5 seconds, press and release the UNLOCK button on the Remote Keyless Entry transmitter. A chime will sound signaling to you that the transmitter link has been successfully disabled. To disable another transmitter linked to either memory position, repeat steps 1-5 for each transmitter. NOTE: Once programmed, all transmitters linked to memory can be easily enabled or disabled at one time. Refer to the Remote Linked to Memory 9Customer Programmable Features 9 in the Electronic Vehicle Information Center (EVIC) for more information.[/size][/font] |
RE: preset setup
Thanks for the info we will try soon both settings are too different for either of them so we got to try to change themthank you again for your help I will let you know how it goes.
Joe |
