Problem Cold Starting
Hi Guys
Got my third Grand Voyager in November last year 2017. Had a few issues cold starting over Christmas. However in January we had major snow and I mean major snow.
The problem was slowly getting worse so I decided it was time to change the Glow plugs. I bought 4 Bosch Glow plugs £88 for 4 and was getting ready to change them. When I removed the cover, however I noticed that No 1 ejector was in fact leaking and from the build up of oil and carbon it was clear it had been leaking for some time.
I therefore decided to get the car started to see if there was any sign of a leak and sure enough when the engine was running you could see air blowing against the solidified oil.
It was clear that the pressure was an issue and changing the glow plug would not solve the issue. I therefore had the garage remover the injector for inspection and thankfully it turned out that it was only the copper washer that had failed.
Copper washer replaced and car starts prefect every time. However i did have the glow plugs changed as well seeing as I'd already bought them
I'm posting this as info for anyone else having similar problems
https://www.dropbox.com/s/ddullszat8..._0002.jpg?dl=0
https://www.dropbox.com/s/wwk86wfgfu..._0003.jpg?dl=0
Yes this is normal problem , I change mine after 230000km 2 out of 4 was leaking and no 1 injector was stuck . Took a weile to pull it out course it had to high leak back so needed to be changed. (it cut out on low rail pressure)
So did drive another 250000km and pull them again just to be sure and there was no problem of course change the washer again and now it has done 520000km still going strong only the clutch has been change 3 times . Springes in the clutch seams to brake.
I suspect the root cause for leaking washer is becourse the injector is getting bad . and cumbustion temp is changing , pull a few injectors and offen the tip look like it has been very hot .
So your problem could be early stage bad injector spray pattern , and course engine to be difficult to start even that the glow plugs is working .
There must not be any white unburnt smoke when starting , if any and your glowplugs working the injectors is bad.
BrianF
11-13-2013 01:22 PM
wwilk
04-18-2012 03:04 PM
