Rb3 sat nav antenna fitment?
Yes remove both A trims then the panel under the windshield (screen) will pull up (no screw) you will then be able to mount the areal and feed it to the RB3 unit. Will need to make sure you have a 5 disc sat nav set to correct preset issues (software update on disc) How much are you paying? As a tom tom would probably be cheaper and better as the RB3 doesn’t have colour screen or post code entry and software updates are expensive.
minivandriver
31
Aug 13, 2011 04:37 AM
