notsofast |
07-02-2019 07:13 PM |
Rear clunking noise fixed/solved
I took the bottom bolt out of the new rear shocks I just put on a month ago. I let the shocks hang down away from the control arms so they wouldn't contact anything. Drove it around the block and it was silent. Took those shocks back under warranty and upgraded from those Gas-Matics to Monroe Spectrums which are what used to be the Sensa-Tracs. Drove it around and it was silent. . The Gas-Matics were in solidly with no loose bushings and no loose bolts. They operated fine on the work bench just like when I took them out of the box. Both types had the same rubber bushings and sleeves
