Removing rear brake drums
How do you remove the rear brake drums on a 1996 Chrysler Town & Country? I've looked everywhere and have found 3 black plugs and removed all 3 and did not find the adjustment.
Thank you. John |
RE: Removing rear brake drums
usually a BFH works for the guys in the shop (BIG F*#$ing HAMMER) it gets stuck on their alot and the hits kinda jar it loose
i dont see any drum hold on bolts or studs or anything it might just need a little bit of help (hit it with a hammer you should not hurt the drum unless its a RBFH really big f h good luck |
Just had mine off today. Just bang around the perimeter with a good, heavy mechanics hammer. spray with WD40 around the spindle and bolt holes, repeat with the banging from the back side, turning all the while. Brake dust will come out. It will be somewhat mobile (although possibly hung up on the shoes) when it is free from the rust lock
