Brandon6304 |
01-18-2017 06:24 PM |
Replaced cv axel on 03 t&c now car wont move
I have a 03 t&c limited, i replaced the cv axle, the wheel hub, tire rod, rotors and brakes on both sides of the front end. Problem is after i got everything put back together and all 4 wheels on the ground, i started it and tried to take a test drive but the van wont movE, If i give it a lil gas it tries to move and if i force it to move the passenger side i hear a grind. If i jack up both front tires off the ground the passenger side wont budge only the driver side spins.. what am i missing i have owned many different years and models of this van and never had a problem replacing parts.
i looked under the car where the shaft seeds in the housing and seems that the cv shaft sould go in a tad bit further but after poping it out and putting it back in still the same. What is going on?
