Replacing fuel rail on 3800
What is the process to replace a leaky fuel rail on a 3.8L? I am assuming it is like the Fords 3.8L?
a. remove upper intake manifold-6 bolts
b.remove throttle body and air ducting
c. disconnect fuel line with quick disconnect
d. disconnect ancillary stationary bolts on the fuel rail electrical connection to FI
e. shimmy fuel injectors out of lower intake manifold along with fuel rail.
f. replace FI O-rings
g. reverse to install
is this all? Anything more? What should I be on the lookout for? The Upper Intake comes out without removing the lower windshield assembly right?
I wanna do this on tuesday on a 96T&C and I want to be prepared.
Chrysler guy
Mar 18, 2012 07:51 PM
johner07
Jan 29, 2012 10:28 PM
