Rough ridin
hey guys... bought this van new and taken really good care of it.. notice it is beginning to ride rougher than usual , even with new tires ( same as always ).. could the shocks be worn at 140000 ? and.. is there 4 shocks and what is difference in shock/strut ? thanks
yes there are four shocks two front and two rear the fronts are called struts or shocks hope this helps
What do you mean by rough riding. Is there knocking or bumping noises from below. Or is it wandering on the road.
Originally Posted by goggs
(Post 94150)
Do the shock test. Press down on each corner (if you can) let it go and it should rise with no bounce. Does steering turn easily with no binding as per top mount seizure. Try fitting front wheels on back and vice versa as this cures or finds faults.
| All times are GMT -5. The time now is 06:21 AM. |
