Rough working
My 2002 TC 3.3Lengines functions smoothly while in neutral, but when I engage the transmission and while standing runs very rough. When running at normal speed it runs smoothly.
any codes in the computer?
rough working
code is 0305.-I have replaced: the crankshaft sensor, spark plug, injector, fuel pump, throttle control sensor, map sensor. Could it be that the ECU needs flashing?:mad:
the 305 is a number 5 misfire a crank,TPS,map sensor has nothing to do with that code nore does a fuel pump u replace the plugs but not the wires? what about the coil pack?
Did u look up what the code means b4 u spent all the money and time on the above things? |
Are you getting consistent spark and fuel injector pulse, when in gear? If yes then check compression.
http://www.obd-codes.com/p0305 |
I just did a valve job
