Severe judder shudder
2003 2.5 crd voyager
Just had the gearbox overhauled due to the noise from the box on tickover (see other thread) replaced the clutch and now have severe judder when going back wards and dropping down through the box, the only thing I can think of, are the engine mounts front and back supposed to be pre tensioned?? Nightmare to be honest |
Sounds like the clutch plate. Possible contamination on it during fitting. Pre Tensioned, Pre Loading, not on engine mounts.
Originally Posted by goggs
(Post 96564)
It's obvious you have an issue here. It SOUNDS like you have a manual box (with a clutch plate) but you are using AUTOMATIC gearbox fluid, (Millermatic). Why? The lubricating requirements for the two types of gearbox are totally different, with completely different additives. However, I can't see that causing clutch judder/shudder. I would still look at the engine mountings and the CV drive joints if this is FWD same as the 2.8 CRD. Unf. as this fault is co-incident with changing the clutch, there may be some fixing error, or there is a manufacturing fault with it. Was it a pattern part? Is the clutch somehow "out of line" now?
Leedsman. |
Could always try bedding the clutch in by slipping the clutch a bit longer between changes just to see if that helps.
Up date, Had my nipper remove the heat shield on the rear mount and fill it with rubber windscreen bond, bit tricky but he managed it, (It was a little tip from a Mechanic mate) left it overnight to set and tried it, virtually eliminated the judder/shudder so have bitten the bullet and purchased a new mounting from the good old USA, having been caught with quality buying local for the front I thought I would see what genuine prices were, I was surprised to find the mount including freight to the UK was only £36 ok so I have to wait a couple of weeks for it but as its a right sod to get at quality matters, I am going to remove the wiper mount from below the windscreen to aid access.
Well have returned from a week in North Devon and the old Voyager performed brilliantly, before I went I had my Nipper fit a new rear engine mount, bit of a pain but its on there, we found if you removed the wiper lump from the bulk head it helpt with access, the vibration now only shows up when the revs are very low, bring up the revs and no vibration, due to a Family bereavement I will now be selling the Voyager, I will put an add in the for sale section and list all I or my nipper have done/changed, it will be a fixed price as I am in no hurry to get rid.
Interesting to know what you think is better than the Voyager as all cars out there have their woows...
(Post 97209)
Yes loads of Auto Voyagers, my next one will need to be one as I have a back problem. As too leaving the Voyager brood, many have done it, but many have returned. But good luck anyway.
