Speedo and rev counter have both stopped
Hi all,
I've recently purchased a 97 Chrysler Voyager SE (UK Model) and this morning both the speedo and revcounter needles have both stopped working. Any suggestions as what the problem might be ??? Thanks in advance. |
RE: Speedo and rev counter have both stopped
I have tried the following proceedure:
SELF DIAGNOSTIC TEST To activate self diagnostic program: [*]With the ignition switch in the OFF position, depress the TRIP and RESET buttons.[*]While holding the TRIP and RESET button turn the ignition switch to the ON position.[*]Continue to hold the TRIP and RESET buttons until the word code appears in the odometer windows (about five seconds ) then release the buttons. If a problem exists, the system will display diagnostic trouble codes. If no problem exists the code 999 (End Test) will momentarily appear.[/ol] DTC'S 110 Memory Fault in cluster 111 Calibration fault in cluster 905 No CCD bus messages from TCM 921 Odometer fault from BCM 940 No CCD bus messages from PCM 999 End of Codes When I tried this I got a code of 999, which presumably is a signal signifying no fault ??? My dash then displayed 3 checks during which the fuel and temperature needles both went to there high and low limits and all the warning lights etc all illuminated, but alas neither my speedo or my rev counter needles moved. Can anyone provide any help ??? |
new cluster or if u want read in other posts about how to repair on your own solder a few points.
The fault seems intermitent, as the speedo and rev counter are now working again.
I've got an Auto Electrician coming over on Thursday to check it out, I'll post any findings. |
Jimbo, I had the same problems in my '96 Grand Caravan. It was never resolved during my 8 years of ownership, because the dealer kept telling me I needed a new instrument cluster. Since it was so intermitent, I never went to that extreme. I traded it on a 2001 T&C so some other bloke is probably dealing with it now. It was fun to watch though...the gagues would just go crazy...flopping from zero mph to 120 mph...full tank to empty tank...I only wish it was coordinated with the music that I was playing at the time!
For some reason the fault seems to have cured itself for the time being.
