Starter Removal 2001 Voyager
Bad day here - hope someone can assist in next step. Trying to replace starter - having no progress in removing the top bolt. Looking to make sure I have the right bolt. The bolt that is stuck/frozen also serves as the ground post - can anyone confirm? I believe the nut is a 15mm, seems to be frozen. Looking to verify that this is the top bolt for the starter.
Thanks for the view. |
upper starter bolt
1 Attachment(s)
make sure you are undoing the correct bolt.
Some people mistake it for the motor mount bolt. Both starter bolts are 15mm. The upper starter bolt has 2 ground wires attached to the bolt, that need to be removed with a 13mm deep socket first (1/4" drive is easier). |
