Starting problems...sometimes
My 2003 3.3 L Grand Voyager has starting problems. The starter motor always cranks, but under certain conditions it can take too long to fire up. When the engine is cold, no problems. Cranking after engine is shutdown, but within about 10 minutes...ok. But after leaving the engine off for between about 10 minutes to a couple of hours, it takes about 5 to 10 seconds to fire up. Why?
Originally Posted by Matt from Oz
(Post 110111)
Originally Posted by REBEL59
(Post 110114)
It's 16 yrs old...any CEL lit on the dash? What maint has it had beyond oil changes? Good chance of a weakening fuel pump.
I changed the fuel pump assembly about three years ago due to my fuel gauge jumping up and down intermittently. I guess the pump might be a cause, but I thought this would cause starting issues all the time? |
(Post 110132)
Thanks for your reply. No CEL lit. Engine fully rebuilt about two years ago. Fuel filter replaced last week.
I changed the fuel pump assembly about three years ago due to my fuel gauge jumping up and down intermittently. I guess the pump might be a cause, but I thought this would cause starting issues all the time? When this happens, have you tried just turning the key to the run position, waiting a few seconds and listen for fuel pump whine(couple seconds) and then doing again before cranking to make sure it is NOT a fuel "bleed down" situation or even loss of electric current to engage the fuel pump? |
Thanks. I’ll try what you have mentioned and keep you updated.
