Too many gear indicator lights
Old Mar 10, 2018 | 11:55 PM
KrisBo the Mombie's Avatar
Default Too many gear indicator lights
Today I got into my 2006 T&C (86,300miles) I tried to start it. Nothing. I never have issues with this van. I tried a 2nd time. It turned on and idled fine, but I noticed in the area under PRND## (I can't remember the numbers) usually only the gear that the van is in is lit up. Which would habe been park, however this time every single spot was lit up. So I turned it off and had it towed home. I was scared to ruin something. I did not drive it at all. I did try 2 more times to turn it on and nothing. Was wondering if anyone e has had this happen. Any ideas?
Old Mar 11, 2018 | 05:45 AM
dieselvoyager's Avatar
Had a Stratus ones that did the same thing , never did it again !
It did not set error code and never did again so it's diffcult to finde the error.
Old Mar 11, 2018 | 06:06 AM
I suspect a bad ground conection or battery was a little low power. I install a optima Redtop battery and never saw the problem again. Later i notis a little drain on battery but never found the problem and I still drive it today.
Old Apr 24, 2018 | 02:52 PM
Leedsman's Avatar
Sounds like the old microprocessor problems again. If your sure the battery is good, disconnecting it for a few minutes should clear garbaged data out of the micros. Clean battery terminals with a round file to bright metal and scrape the lead poles of the battery with a knife while waiting, then a little Vaseline on the battery post, then refit.
If this clears the the problem for a while, good. If it comes back, you must find what is garbaging the micros. Glitches on the 12volt line are usually the cause.
Leedsman.
DJBowens
Apr 26, 2011 05:44 PM
Dodgegirl19
Apr 10, 2011 06:08 AM
Badger
Jan 10, 2010 02:54 PM
wrenchpuller
May 21, 2008 03:23 PM
Dodgegirl19
Nov 18, 2005 02:24 PM
