Towing
Hi All,
New memeber from South Wales and a Chrysler Voyager novice. Just glad I have found this Forum. I have a Voyager 2.5 CRD 2003 and have just started towing with this unit. I am a little concerned as the temperature gauge rises to the halfway mark when towing. Is this normal? As previous vehicles have never done this. |
my 01 3.8L town and country opperates 1 notch below half way under normal operation, not towing.
i have a 1998 2.5td voyager when towing the caravan up a long hill the temp does rise a bit as the engine is under a lot more load ,check to make sure the cooling fans are working,sounds normal though
Thanks Dan,
Just a little worried as don't want any overheating problems. Fans do come on when aircon running but I have not heard them coming on apart from that. I am not sure at which point on the temperatue guage they kick in. I must confess last time I towed it was a very hot day and in stop start traffic for a while. |
We tow with a 2.5TD as well, and the temp is a little higher most of the time, but when we go up a big hill it does go up quite a lot, but then comes back down when you start a descent. Towing is the only time that I have ever heard the radiator fans come on.
Steve |
My 3.3 used to warm up when towing.
The rad went so I changed it, It NEVER moves over half now, but it stays at half all the time. Its not an easy job without de-gassing the Air-Con, but I managed it with skinned knuckles! |
