Town & Country 2001: No heat in front
Hi,
I am a new owner of a 2001 T&C with automatic temperature control. I am experiencing an issue with the heating system as follows: - no matter what degree I select, it blows only cold air in the front; the rear does get warm/hot air in the meantime. Issue only exists for the front. Any help/input would greatly appreciated! Thank you!!! |
RE: Town & Country 2001: No heat in front
coolant level low
Hi Chrysler Tech,
Thank you for your quick reply. I filled the coolant level back to the max, but it still doesn't blow hot air. Do you have any other ideas? Thanks. |
did u just look in the over flow or did u look in the radiator itself as well?
I assume the overflow (the little plastic container that shows the Min and Max levels) only. How would I check the radiator itself? Thanks again!!
open up the cap thats on the radiator left side push down and twist to the left.
Ok, thanks. Radiator is full as well. Still not working. Could it be an electrical problem, since it sat for 7 months on a lot before I bought it this past weekend...
if u can locate the motors on the driver side under the dash look for the one that will move when u trurn the air temp the others ones would be for air direction.
motor for temp is working. when chaning temperatures the "lower" motor is engaging. (still only cold air blowing.)
then u have a clogged heater core then feel the lines that go into the fire wal if one is colder then the other it is clogged up.
